banshee Posted October 26, 2015 Posted October 26, 2015 Anybody running without a high valosity joint? Meaning extend shaft and replacing HV with standard Ujoint
gogmorgo Posted October 27, 2015 Posted October 27, 2015 You mean replacing the constant velocty (CV) jont? Which is already just two matched u-joints? Sounds like more trouble than it's worth to me. What would you be accomplishing? Correct me if I'm wrong, but to do it, not only would you need a longer driveshaft, you'd also need to change your pinion angle so it matches the front T-case angle, instead of just being pointed right at it, which means relocating your control-arm mounts on the axle to correct the caster... and probably relocate the body-side control arm mounts and play with control-arm lengths to keep the pinion angle reasonably constant through the range of axle travel. To do it properly, that is. I imagine on a strictly off-road vehicle you could get away with less.
