ComancheFan1991 Posted October 2, 2015 Share Posted October 2, 2015 How do you swap a HO 4.0L into a Renix while keeping the HO power and electronics? I know it requires a harness swap and, ideally a donor '91 up Cherokee. But what things have to be changed, and can the cluster be kept the same on column automatics as most Cherokees have a floor shifter? Link to comment Share on other sites More sharing options...
MrSimon Posted October 2, 2015 Share Posted October 2, 2015 How do you swap a HO 4.0L into a Renix while keeping the HO power and electronics? I know it requires a harness swap and, ideally a donor '91 up Cherokee. But what things have to be changed, and can the cluster be kept the same on column automatics as most Cherokees have a floor shifter? Yes, it can be done. I put a 99 XJ motor/trans/TC into my 87 MJ and didn't change a thing in the interior of the truck. I kept the same gauges and column shift. The wiring harnesses had to be merged together, a few relays added, and most of the sensors needed switched out. Unless you are really good at this kind of stuff, I'd recommend you find a good shop to do the swap for you. That's what I did and it was worth every penny. I'm pretty sure the computer and everything else electrical was swapped over from the XJ ... so the truck thinks its a 99 XJ. I'm not completely sure, but I think the old sensors and sending units (cooling, oil pressure etc) had to be moved over from the Renix to the HO so the original MJ gauges would work properly. Link to comment Share on other sites More sharing options...
