stock 4x4 height?
OK so I got a jeep Comanche its so not stock anymore but I need new shocks for it. However I'm having a hard time figuring out how long they need to be. When I first got the truck it had 215/75r15's on it they sat up in the wheel wells. Now it has p235/75r15's and there is about 8-9 inches from the top of the tires to the bottom of the fender flares. So far I have been running stock shocks but I keep maxing them out. So I want to fund some better ones. Any help would be great thnxs.
Here is what,I have done to it since I got it:
Was originally 2wd converted to 4x4 Dana 35 front Dana 30 rear manual 5sped ax15 trans with a np231 transfer case.
Front stock coil spring swapped out to 78 ford f100 coils (I know what is a ford part doing on a jeep but they are twice the size of original and still give an amazing ride on road and off road) has 1 1/2 spacers on top of the coils
Rear leafs added to make 8 total per side whith rearching.
Rear shackles extended by 4 inches.
Engine is renix 4.0 but getting upgraded exhaust to header style to improve flow.
Electrical upgraded. Stock alternator swapped out for a 110 amp. Second 110 amp alternator added in for better power output.
5 forward facing roof mounted lights with 2 fog lights on the bumper. 4 rear facing roof mounted lights for night rides and auxiliary lights.
Truck is a late month 1989. But is currently off the road because I'm in the process of rebuilding it.
