Brbrooks83 Posted September 19, 2015 Share Posted September 19, 2015 Started having a odd problem but not sure it's the tranny going bad. 1987 comanche 2.5 auto. Can be driving down the roar at highway speed and when in drive it acts like it's in neutral and revs up it you can slow down or stop shut it off and then back on and all is good for a couple mile and then does it again. Also you and pull it down in 3rd and it's fine. Checked fluid and looks good not burnt. Anybody had this issue and can help I sure would appreciate it. Thanks Brandon Link to comment Share on other sites More sharing options...
gogmorgo Posted September 19, 2015 Share Posted September 19, 2015 Sounds like the torque converter isn't locking up and/or is unlocking. Don't really know how to address that, though. Out of curiosity, how does it behave if you unplug the trans computer and try to shift manually? The trans computer is under the passenger side of the dash, on the back of the small lower panel that runs all the way across, about where the passenger's left knee would be. With it unplugged, you'll need to do your own shifting. Put the shifter in 2-1 for first gear, 3 for third, and D for overdrive. Remember to shift down again on the way back down, and yes, you can't use second gear without the tcu plugged in. P, R, and N should all function normally. Link to comment Share on other sites More sharing options...
Brbrooks83 Posted September 19, 2015 Author Share Posted September 19, 2015 Ok I will try that. It's weird sometimes it does it and sometimes it don't. I drove it this morning pulled out the driveway and shifted into drive and was like it was in neutral stopped shut it off and started back and ran great Link to comment Share on other sites More sharing options...
