Gas tank parts
  • 2 months later...
Put the rubber piece in the tank first, then use some sort of lube (like white grease, or chassis grease or really slimy boogers) on the plastic and the rubber ID and push the plastic piece through.   It should go with a bit of fiddling.  Good luck!!
