JENSSEN Posted August 26, 2015 Share Posted August 26, 2015 I found something of interest can anyone help me decode this VIN? I am working off my phone and not having any luck. 1JTBL65LXGT115913 Thank you in advance! Link to comment Share on other sites More sharing options...
shelbyluvv Posted August 26, 2015 Share Posted August 26, 2015 VIN : 1JTBL65LXGT115913Check Digit Test : VIN errone - Check digit EDIT: for wrong VIN. Link to comment Share on other sites More sharing options...
JENSSEN Posted August 26, 2015 Author Share Posted August 26, 2015 So not a metric ton truck? Link to comment Share on other sites More sharing options...
shelbyluvv Posted August 26, 2015 Share Posted August 26, 2015 The "L" in the 8th digit is messing me up. I don't see that code listed for the 86 as a payload option. Are you sure it is not a 1? Link to comment Share on other sites More sharing options...
JENSSEN Posted August 26, 2015 Author Share Posted August 26, 2015 The "L" in the 8th digit is messing me up. I don't see that code listed for the 86 as a payload option. Are you sure it is not a 1? Link to comment Share on other sites More sharing options...
shelbyluvv Posted August 26, 2015 Share Posted August 26, 2015 That's more better! Notice the check digit is valid now. It is a standard payload Comanche Custom. VIN : 1JTBL651XGT115913Country : United StatesManufacturer : Jeep CorporationVehicle Type : TruckEngine : Turbo Diesel, 2.1 Liter, RenaultPowertrain : 5 Speed, Manual Transmission, Floor Shift, Part Time Transfer Case 4 WDLine (Body Type) : Comanche Truck, 4 WD, 7 ft BoxModel and Gross Vehicle Weight : Cherokee Base Model, 4001#-5000# GVW * Comanche Custom Model, Standard Payload [1815/2268 Kg]Check Digit : XYear : 1986Plant Location : Toledo, Ohio, USASequential Serial Number : 115913Check Digit Test : VIN valide Link to comment Share on other sites More sharing options...
JENSSEN Posted August 26, 2015 Author Share Posted August 26, 2015 What's a standard Comanche custom??? The custom has me confused Link to comment Share on other sites More sharing options...
shelbyluvv Posted August 26, 2015 Share Posted August 26, 2015 Standard payload as in non metric ton. The custom just means it's a base model truck. They were available in 86 as a, Custom (bare bones base model), X (a bit nicer), XLS (the Laredo equivalent in 86) Link to comment Share on other sites More sharing options...
JENSSEN Posted August 26, 2015 Author Share Posted August 26, 2015 Hmmmm it's a complete diesel and he says the heads cracked What to do, what to do Link to comment Share on other sites More sharing options...
