Need help finding Header for my 86 2.5l
If you look at replacement stock manifolds they are the same part for egr or non egr systems. You just plug the egr port for the ones that don't need it. Therefore it can be extrapolated that the header like the one from aFe twisted steel that doesn't have an egr port will bolt right up.
#<:(>,/ ?[\&=% ]>=:= [# $&>\.... Sorry for the profanities, now that I had the chance to remove my stock,and fully cracked 360 on #1, I see why 91 and newer headers don't work for my 86. The problem lies in the Intake manifold shape for my model. My intake is more squared and the newer style is more a horse shoe,giving the newer more space.
Also the power steering bracket also interfered with #1 which I figured I could fix/cut/fabricate to work,then I relized my new headers pipes stick out to far,making it so the intake doesn't touch the head.
