SBpunk Posted August 16, 2015 Posted August 16, 2015 So dropped my fuel tank to fix my sending unit. Now I can't get a good seal on the sending unit. There is a small rubber piece that presses into a hole at the bottom of the tank and I'm wondering how important it is. I can get a good seal without it but having issues getting it pressed in with it on.
SBpunk Posted August 16, 2015 Author Posted August 16, 2015 Ok got it figured out so far. Put some vasoline around the rubber cone and the o-ring. Seemed to seal up nicely and now I can tell that I'm out of gas......
SBpunk Posted August 17, 2015 Author Posted August 17, 2015 So go the fuel pump in and still just hanging under 1/4 tank. Manually moving it registers on the dash but no luck while it's in the tank. Any ideas?
