I'm looking for a replacement air cleaner hose.  I have the two harnesses you can purchase, but this hose is separate.  This is the hose that goes from the air cleaner, all the way across the back of the firewall, to the passenger side to hook into the vapor canister.  It's a U shaped style hose, but the generic section is no luck.  I also need the hose on the other end that goes from the big plastic piece to the vapor canister, it's larger on one side than the other.
I have the parts book, it's listed as 53004623 for the entire assembly, the plastic piece all along the firewall, etc..  I just need the rubber end pieces...  Was hoping someone had already  found something that fit from some other application.
