Auto to manual conversion flywheel and clutch bolts
I'm gathering all the parts to convert my 2wd auto to a 4wd manual.  I have the correct flywheel and clutch, but I'm curious if I will need some new bolts?  With the bolts that hold up the current flexplate work on the new manual flywheel?  Do I need some new bolts for the clutch?
If so, can you order them somewhere or do I need to head to the pull a part?
