Looking to see if anyone has a set of Renix vacuum lines that will fit my 87 4.0 before I order new ones thru NAPA. I am needing the entire assembly after the valve cover and also needing the throttle body to MAP sensor line.
Just an FYI I know NAPA has been mentioned hundreds of times as being the place to get these hoses. I just want to clarify that Dorman makes the hoses (or resells them also), so if you need to buy new you might get them cheaper on Amazon. I bought the Dorman sets (two different sets are needed for Renix).
Dorman 46004 http://www.amazon.com/gp/product/B000630DJO/
Dorman 46003 http://www.amazon.com/gp/product/B000630DJ4/
