The Phoenix
This will be my attempt at documenting the rebuilding, building and modifications of this new to me 1987 MJ. I've never been really good at taking "in process" pics but will try harder as time goes on.
This is the first picture I have of it.
More to come!
It hasn't been on the streets for countless years, so the first order of business is to get it running, driving and stopping. A couple gallons of fresh gas and it fired right up! You can't keep a good Jeep down! completely new brake system and she stops pretty good as well.
While doing the brake job I noticed a lot of frame rust. I knew it had a previous repair but missed just how bad it really is.
After seeing how much rust it had I was torn if I should scrap it and buy another or fix this one. After consulting with fellow Comanche owners I've decided to just keep it and fix it.
I started by cutting access holes in the top to clean out, treat and coat the inside of the frame rails. I then repeated the process on the outside.
As you can see there are additional spots that need to be cut out and new steel welded in. I have yet to tackle the really bad spots.
Rain finally stopped long enough for me to get back to work. Started on the drivers side frame rail, it's the better of the two. Cut out from the front spring hanger to about midway to the transfer case. Was I surprised what fell out! The rail was over half full of sand, dirt, mud... Perfect recipe for disaster.
also the perfect recipe for a lot o fun, so least she brought smiles to someone.
