Jeepjeff859 Posted July 3, 2015 Share Posted July 3, 2015 So next Thursday I'm going to the junk yard to pull parts for my swap From a 1994 Cherokee My list is Engine and dash harness Motor mounts Fuel pump Radiator Radiator support Heater box And hope fully the computer if its still there Is there anything else that I absolutely need to get 1994 grand Cherokee engine Ax15 transmission Link to comment Share on other sites More sharing options...
Jeepjeff859 Posted July 3, 2015 Author Share Posted July 3, 2015 Unless I can use parts from a 1995 Cherokee Link to comment Share on other sites More sharing options...
Jeepjeff859 Posted July 3, 2015 Author Share Posted July 3, 2015 Not a bad idea Link to comment Share on other sites More sharing options...
Jeepjeff859 Posted July 3, 2015 Author Share Posted July 3, 2015 But I'm still wondering if a 1995 Harness will work with a 1994 engine Link to comment Share on other sites More sharing options...
Rockfrog Posted July 4, 2015 Share Posted July 4, 2015 Yes, the 95 uses the same wiring harness as a 94, same fuel system, same blah, blah, blah, the next big change wasn't until 96. 94 was an electrical connector change year and the 95 used the same harnesses. Link to comment Share on other sites More sharing options...
Jeepjeff859 Posted July 5, 2015 Author Share Posted July 5, 2015 Ordered my cutch today from rock auto, I went with a luke fly wheel and a 1993 clutch kit because my ax15 is internal, I check the parts numbers for the fly wheel and the are the same between both years and I also ordered a couple different pilot bearings Link to comment Share on other sites More sharing options...
