JeepsOLot Posted June 21, 2015 Share Posted June 21, 2015 Ok, getting ready to take this bed off the parts Jeep ('89 SB), and I can only find 6 bolts/studs, and I heard there's supposed to be 8. So far, on each side, I have one stud all the way forward, one bolt just ahead of the rear axle, and one stud at the very rear. I see a hole in the frame just behind the rear axle, but doesn't seem to be anything there. Now, I should mention, I haven't dropped the tank yet, so, I know that still has to come. Am I missing another set of studs/bolts? Thanks! Jerry Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 21, 2015 Share Posted June 21, 2015 Link to comment Share on other sites More sharing options...
jimoshel Posted June 21, 2015 Share Posted June 21, 2015 Don. Since it's no longer pertinent could you please delete the above post? Have to be a little faster next time. J Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 21, 2015 Share Posted June 21, 2015 Don. Since it's no longer pertinent could you please delete the above post? Have to be a little faster next time. J :thumbsup: Link to comment Share on other sites More sharing options...
JeepsOLot Posted June 21, 2015 Author Share Posted June 21, 2015 Thanks, really appreciate that. If I'm looking at this right, there are only 6 bolts/studs holding the bed on, right? If that is the case, I got them all, just need to drop the tank, unplug the wiring and fuel lines, and e-brake adjuster, and the bed should come off. Jerry Link to comment Share on other sites More sharing options...
