Turn signals
The blue and "Wagner" cans are the flasher units on the fuse panel (drivers side foot well). One is for the turn signals; the other is for the emergency flashers. Swap them and see if your symptoms change.
183739d1364609089t-need-wiring-fuse-box-
Probably bad/wrong bulbs, a bad socket, or a combination of both. Start pulling the bulbs to make sure they are correct, and clean the goop out of the sockets. Check for power at each socket when the signals are energized.
1157 or 2057 bulbs are okay. They are dual filament; they could be shorted in the socket(s). You need to get into each socket with a test light and see what's up.
That's just a generic pic of the fuse box - not mine.
  On 6/1/2015 at 4:33 PM, tylergrant2011 said:
Can I spray contact cleaner in every socket?
Yes. And click on the link in my signature and view Tip 3. There's a lighting connector in a photo there that is notorious for being corroded.
