rearview Posted April 20, 2015 Share Posted April 20, 2015 Drivers floorboard has the rust issue at 2 on a scale of 1 - 10. Anyone tried naval jelly to kill the rust or does the need to wash off make it a bad option. Worried about the area under the reinforcing tunnel. Looks like the leak is coming in through the wiper motor area. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted April 21, 2015 Share Posted April 21, 2015 Naval jelly is only good for surface/very light rust. If you have rusted floors that penetrate thru the floor you'll likely need a more aggressive treatment. To get down to bare metal try some coarse sandpaper or a flap wheel and get rid of all the rust. Then treat it with a rust killer/inhibitor. Then you can topcoat that. But fix that leak first. Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted April 23, 2015 Share Posted April 23, 2015 I used naval jelly on a table of mine and it worked great Link to comment Share on other sites More sharing options...
sloride Posted April 24, 2015 Share Posted April 24, 2015 I used naval jelly on a set of Keystone Klassic wheels I had back in late '70s. Worked great. But for what you're doing, I'd use something like Por-15 rust inhibitor. Link to comment Share on other sites More sharing options...
