Jeep Driver Posted April 18, 2015 Posted April 18, 2015 Image Not Found Elsewhere you said that you would have gone +20 of you were to buy new wheels again. 18x9...correct? Assuming +-0 is 4.5" or center- +20 will move center back 3/4" or to 5 1/4" backspacing....correct? Do you have any problem with rubbing at full lock? I'm moving from WJ lowers to adjustables ....any problem you can foresee there? Tire size will be 285/60/18. What tire size do you have? The wheels I'm considering are offered with +14......good compromise? Thanks
