Factory 1991 HO fuel injectors Missouri
schardein
EDIT:  I'm in Missouri
I have a 1991 Xj and a 1991 MJ.  I replaced all the fuel injectors with 4 hole type from the junkyard.  I've noticed very slight improvement in idle quality, and a small mpg gain, but I replaced the O2 sensor in the MJ at the same time, so who knows.
Anyway, so I have 2 sets of 6 factory HO fuel injectors.  Both trucks are daily drivers and ran fine before they were pulled.  One injector is missing an o-ring, I pinched one when installing the 4 hole injectors, so I had to rob one (oh no!  I reused o-rings!  It's been a month, no leaks).
Price is $32 PER SET, SHIPPED.  That is less than half what a junkyard injector costs around here.  Make an offer if you are interested in both sets.  First set sold will be o-ring complete.
They all have the fuel rail clips.
  • 2 months later...
Archived
