88mjblue Posted January 19, 2015 Share Posted January 19, 2015 I need to replace my front sway bar bushings and was wondering what you guys went with when doing yours. I know there are rubber, polyurethane, and I also saw these greaseable bushings with hold-down brackets that have zerk fittings so you can grease them periodically. Link to comment Share on other sites More sharing options...
91Pioneer Posted January 19, 2015 Share Posted January 19, 2015 I put Moog sway bar links on mine, plus Moog bushings on the bar. My old ones were rotten so it handled tighter after I was done. Cheap, not rubber (I think it was polymer plastic or something). They fit and work great. I put a little synthetic brake slide grease on mine since it was safe for use with rubber. I see no need for the greasable ones for my driving. http://www.amazon.com/gp/product/B000C542SO/ and http://www.amazon.com/gp/product/B000C55Y5Y/ If you're buying bushings for the end links, you should just buy new end links. My nuts snapped off because I had bought bushings already. I had to return them and buy the links. Link to comment Share on other sites More sharing options...
88mjblue Posted January 19, 2015 Author Share Posted January 19, 2015 I put Moog sway bar links on mine, plus Moog bushings on the bar. My old ones were rotten so it handled tighter after I was done. Cheap, not rubber (I think it was polymer plastic or something). They fit and work great. I put a little synthetic brake slide grease on mine since it was safe for use with rubber. I see no need for the greasable ones for my driving. http://www.amazon.com/gp/product/B000C542SO/ and http://www.amazon.com/gp/product/B000C55Y5Y/ If you're buying bushings for the end links, you should just buy new end links. My nuts snapped off because I had bought bushings already. I had to return them and buy the links. Thanks for this. I remember reading your post about these somewhere and couldn't find it again or who posted it. I will be getting these Moog bushings for my sway bar. I'm considering getting the sway bar end link kit as well, but was thinking I might as well spend the extra money and get some quick disconnects instead if I'm going to be replacing them. Anybody have any positive experiences with a good quick disconnect? Link to comment Share on other sites More sharing options...
big66440 Posted January 19, 2015 Share Posted January 19, 2015 I'm using poly bushings on the links and the frame, I noticed a difference in handling and no squeaks so far. Link to comment Share on other sites More sharing options...
