Beorn of Ga Posted December 13, 2014 Share Posted December 13, 2014 I have the traditional leaking clutch cylinder. Does it unbolt from the fire wall without me having to get to hardware inside of the cab ? Link to comment Share on other sites More sharing options...
yxmj Posted December 13, 2014 Share Posted December 13, 2014 No most the hardware is inside There is a cotter pin that connects the plunger to the pedal shaft. then the top bolt and nut....the bottom is the only part you get from the engine bay that nut is just on a stud Link to comment Share on other sites More sharing options...
Brickmiata Posted December 13, 2014 Share Posted December 13, 2014 Its a pretty easy swap once you find a good angle to get under there. extensions and maybe a swivel are your friends Link to comment Share on other sites More sharing options...
