shift linkage for trans swap
If the original was a ba10 like mine, take the bracket the bolted to the transmission, remove it from the rod that pivots in it, turn it around so the side that used to face the transmission, now faces the tunnel, install the entire ba10 linkage.
It's not quite a perfect fit lining things up but once the bolts go in and a minor adjustment is made to the adjustment rod in the assembly, it works very well.
You may have to widen the bolt hole in the bracket you reverse as well. My ax15 had a larger unused hole that worked perfectly.
