Jaxso32 Posted December 2, 2014 Posted December 2, 2014 88 longbed ba10/5 swap to an ax15 from a 97 xj. Everything has bolted up like it is supposed to, but now I have to get the ax15 crossmember in and it won't line up. I'm using the rear set of holes in the frame and all but the stud line up more or less. Any ideas?
Jeepman Posted December 2, 2014 Posted December 2, 2014 Are you using the BA/10 Trans Mount or the AX15???
