looking for a cab back and glass. Need from just below the lower body line to across the roof. I'm in east Tn. needs to be within a reasonable driving distance. thanks guys
I have a back that can be cut out of an 88 parts truck with the single window in NE.
  I would like to find one at least in the southeast area but thanks any way.
  • 2 months later...
Rusty's Pick A Part - Marion NC - supposedly has an MJ. Been trying for weeks to get pictures.
919-552-7228 - Number ( near raleigh, nc if my notes are correct ) 89 MJ no motor parting out.
I'll give them a check. The problem I'm having with Pullaparts, They won't allow you to use anything that throws sparks or uses a flame and they have no electric outlets for a sawzall
If this is a common issue with you, I would suggest a battery powered sawzall. I have a 19.2v kit from craftsman that included a drill, sawzall and a couple of others. Use them all the time.
I needed that ^^^^ again yesterday with the roll-bar ordeal... and last weeks "I only want the bottom of the bench seat for the brackets" fun.
