1990 Comanche Posted November 9, 2014 Share Posted November 9, 2014 Have a 1990 Comanche that is new to me. Need to find an answer to the following simple question:Should the battery light come on as a check when the ignition is on and the engine not running? Most cars do this so that you know it is working. Mine is dark all the time, I have checked the bulb and it is good.I am concerned that the whole warning light circuit is not working at all and need suggestions on how to resolve it. Alternator and battery are working fine.Thanks Link to comment Share on other sites More sharing options...
projectMANCHI Posted November 9, 2014 Share Posted November 9, 2014 Have a 1990 Comanche that is new to me. Need to find an answer to the following simple question: Should the battery light come on as a check when the ignition is on and the engine not running? Most cars do this so that you know it is working. Mine is dark all the time, I have checked the bulb and it is good. I am concerned that the whole warning light circuit is not working at all and need suggestions on how to resolve it. Alternator and battery are working fine. Thanks that light controls wether the alternator is charging the battery, ( well it does on my 86) there is a 10 amp fuse for it either labeled gauge or instrument cluster, and yes it should come on when the ignition is on until you start your truck. check and see if that 10 amp fuse is blown, if you can't figure out which one it is i recommend replacing all your 10 amp fuses( the fusebox inside the truck) Link to comment Share on other sites More sharing options...
1990 Comanche Posted November 10, 2014 Author Share Posted November 10, 2014 I thought the light should come on. I will have to look into it further.thanks Link to comment Share on other sites More sharing options...
