gabe.jessie Posted October 20, 2014 Share Posted October 20, 2014 okay so i saw and xj at the junk yard it has a list would it fit my 91 mj pioneer and if i took the front coils and rear leafs what else would i need to run to make it fit Link to comment Share on other sites More sharing options...
Tommy Posted October 20, 2014 Share Posted October 20, 2014 Coils are ok. Leaf springs are shorter on the xj Link to comment Share on other sites More sharing options...
Eagle Posted October 20, 2014 Share Posted October 20, 2014 What year is the XJ? Link to comment Share on other sites More sharing options...
dasbulliwagen Posted October 20, 2014 Share Posted October 20, 2014 Front lift parts will fit, rear lift parts won't, but grab them anyways, Someone you know might want them later. As well as front springs, grab any other non stock looking parts up front. Depending on lift height it may have aftermarket control arms, shocks, track bar and steering parts, and sway bar links. Control arm drop brackets are another possibility. All those parts work together to make front end geometry right, so get them as a set if you want them all. Depending on the lift height on the XJ as well, if its in the 5 inch range, you can go spring over axle in the rear of the MJ to get the rear lift you will need. Link to comment Share on other sites More sharing options...
