Correct replacement for Renix 4.0 Flexplate?
Anyone have a source for the correct flexplate replacement for renix 4.0's? I've done a search and have found brands such as Crown and ATP don"t "clock" the windows for theĀ  CPS correctly, do you guys have the factory part number or know if the Omix-ada one is correctly positioned, thanks.
A factory part number won't help, since the factory doesn't make them any longer. Crown uses factory part numbers for their parts. About ten years ago I installed a Crown flex plate in an '88 XJ and it worked fine. I have heard isolated reports that they are now clocked incorrectly, but I have no first-hand information on this.
