Starts then dies, with a twist.
I figured it out. The truck had a bad ecm. Whoever worked on this thing before me got so lucky with what they did.Basically we all know the fuel pump relay has four contacts. One is ground from the ecm, one is power from a fusible link, one is the fuel pump and the fourth is a trigger i believe. So what they did is added a wire from the fuel pump at the tank on tue power leg, then they hooked that to the ecm ground leg. For some reason the ecm ground was outputting 12 vdc. So that went down the added wire hit the pump, then back fed up the original power wire to the fuel pump. At the relay i believe it was enegizing it backwards. Allowing the truck to get spark and run. Crazy.
