thejim42 Posted September 30, 2014 Share Posted September 30, 2014 Before anyone gives me the ax15 or nv3550 speech I'd just like to point out that I know they are better options. But I'm on a budget and the only thing I need for my 4x4 swap now is a trans. I found a ba10/5 with just under 100k on it out of a yj with the 4.2. I also have an np207 t-case with 107k on it with the same spline count. I've read that the ba10s came with either 207s or 231s. Will this work behind my 4.0? Id really like to get my 4x4 swap done before winter. Link to comment Share on other sites More sharing options...
Eagle Posted September 30, 2014 Share Posted September 30, 2014 The 207 isn't as good as the 231 and, IIRC, the low range is 2.6x:1 rather than 2.72:1, but there's no reason it won't work. Just remember that the YJ transfer case shifted with a lever mounted rirectly to the t-case. I believe you'll have to change the linkage to get it to work with an MJ frame-mounted shifter. Link to comment Share on other sites More sharing options...
thejim42 Posted September 30, 2014 Author Share Posted September 30, 2014 The 207 I have is out of my 86 mj. I have a 231 but its a 23 spline input. Not to worried about low range because I don't do much heavy off roading. I'm just looking for something that will get me through the winter so I can save up for an ax15 or nv3550 Link to comment Share on other sites More sharing options...
thejim42 Posted October 2, 2014 Author Share Posted October 2, 2014 What would be a reasonable price to spend on a ba10/5 Link to comment Share on other sites More sharing options...
Eagle Posted October 3, 2014 Share Posted October 3, 2014 What would be a reasonable price to spend on a ba10/5 Zero. Seriously. I have the BA 10/5 in my '88 XJ and it's still going at 287,000+ miles, but if it were to blow I wouldn't try to repair it and I certainly wouldn't spend money on another one. My 'druthers would be the 3550, but that's pricey so I would probably go with an AX-15, and look for a post-94 to get the external slace cylinder. Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 3, 2014 Share Posted October 3, 2014 I'm just looking for something that will get me through the winter so I can save up for an ax15 or nv3550 Where do you winter? Link to comment Share on other sites More sharing options...
thejim42 Posted October 3, 2014 Author Share Posted October 3, 2014 This winter will be in indiana and I can't find an ax15 near me. All I've found is a ba10 with just under 100k. But I'm pretty sure $500 is too much with no bellhousing or t-case. Link to comment Share on other sites More sharing options...
Eagle Posted October 3, 2014 Share Posted October 3, 2014 http://www.car-part.com/ Link to comment Share on other sites More sharing options...
