I have a 89 2wd. Comanche 5 speed. 4.0. Can get a deal on 89 4wd. Cherokee 4.o auto. with bad motor,good trans. transfer case front and rear end.Other than shortening my rear driveshaft and matching my gear ratios,(will probably weld spring pads to bottom of Cherokee rear end)is there anything special I'll need.Everything else should be on the Cherokee I believe.Also,was wondering what works best(easiest) for the E brake,Using the M.J.cable and leaving the foot E. brake of using the X.J. cable and using the hand brake?
