hey guys i have a new to me 86 mj mostly stock that i can tell 180,000 mile 2.5   my problem  is when starting the engine it cranks over fires off and has a stumble like its running on 2-3 cylinders this happens for 3-5 seconds clears up and runs like a champ, it runs fine down the road and has good power with no skip   my issue is only on start up it has new plugs and wires i also pulled intake cap off and watched the injector it does not produce much spray for start up  but does have a nice uniform spray once running  any help would be appriciated thanks
Begin by cleaning the ground strap connection at the firewall. Remove the bolt, scrape the firewall to bare metal, polish up the terminal, and reattach.
