Distributor question, MPI to TBI
My distributor has a wobble at the rotor. I know this to be a fact because I started the truck with the dist cap that is cut open for indexing just to watch it function. This engine is a '88 TBI Renix.
The distributor I want to use in out of a '98 Wrangler 2.5 MPI, it has the cam sensor built in.
I want to cut the wire to the sensor plug and ignore that's its there.
I cannot see how or why it would be indexed any differently, and physically the two look alike.
Do you see any reason I cannot use the '98 distributor with the Renix ignition?
Thanks.
