thebabybrahm Posted August 16, 2014 Posted August 16, 2014 need some how-to info on changing drivers side front axle u-joint please!! help!!
Jeep Driver Posted August 16, 2014 Posted August 16, 2014 Remove brake caliper and rotor. Remove axle nut, 36mm socket. Loosen the three bolts behind the knuckle that secures the unit bearing, loosen about 2 turns. Tap the heads of the bolts until the unit bearing releases from the knuckle. Remove the three bolts. Remove unit bearing. Axle will now slide out. Replace U-joint.
AeroNautical Posted August 17, 2014 Posted August 17, 2014 Remove brake caliper and rotor. Remove axle nut, 36mm socket. Loosen the three bolts behind the knuckle that secures the unit bearing, loosen about 2 turns. Tap the heads of the bolts until the unit bearing releases from the knuckle. Remove the three bolts. Remove unit bearing. Axle will now slide out. Replace U-joint. Yep, but more often than not, the hub will not come off easily. I had to place a socket between the hub and axle, turn the engine on and use the power steering to pop it off. I don't recommend that, though. Alot can go wrong if your not careful, especially if your on jack stands.
thebabybrahm Posted August 17, 2014 Author Posted August 17, 2014 thanks guys, gonna dive in on it when i get back from the beach
