Ok so I just put a new clutch in my jeep but now when I bleed it it goes from soft to very very stiff towards the end of the travel, do I just need to keep bleeding it to get it as stiff as possible?
I found out something interesting today. Apparently there are two different thicknesses for the throwout bearing. Make sure its The right thickness
yes i compared the two and the new one is the correct one. But i did realize after bleeding the clutch for a good while that the pedal is like stuck down a little bit and won't release all the way up even if pulled onĀ
I used a some emmry paper to polish the hole and the dowel, put a little bit of oil on them and used a c-clamp to pop it on
