86 mj Posted August 1, 2014 Share Posted August 1, 2014 has anyone ever replaced the sliding window glass and if so how did you do it thanks Link to comment Share on other sites More sharing options...
Eagle Posted August 2, 2014 Share Posted August 2, 2014 I don't think it can be replaced -- because it doesn't exist. Tye MJ rear sliders aren't flat, the glass is curved, and nobody makes replacement glass for them. I know -- I have a friend who runs a glass company, and we've searched. Link to comment Share on other sites More sharing options...
86 mj Posted August 2, 2014 Author Share Posted August 2, 2014 thanks... we got the glass Link to comment Share on other sites More sharing options...
Jeep Driver Posted August 2, 2014 Share Posted August 2, 2014 thanks... we got the glass I love useful and informative posts. Link to comment Share on other sites More sharing options...
Eagle Posted August 2, 2014 Share Posted August 2, 2014 If you have the glass, you are thre--quarters of the way. The whole window is glued into the body like a windshield. The outer "gasket" is trim. The slider assembly has a top rail and a bottom rail, with the ends open such that, on the ends, the glass is glued directly to the body. I don't think there's enough vertical clearance to pop a new slider glass into the tracks in the vehicle, so I believe you will have to remove the entire window assembly, spread the top and bottom tracks to insert the new glass, and then reinstall the window and the trim gasket. Link to comment Share on other sites More sharing options...
