86 2.5 5Sp 4X4 Long Box
Clutch. Flywheel.
Clutch shudder is often (usually?) a result of someone slipping the clutch too much, causing hot spots on the flywheel. The only real cure in that case is to replace the clutch and the flywheel, or have the flywheel resurfaced (the latter being a severe NO-NO for the 4.0L flywheel but is apparently okay for the 2.5L flywheel).
