Vacuum Canister
Dando
I am looking for a vacuum canister for my 90 4.0 with cruise and a/c. I currently don't have one as the stock one is cracked apart after 25 years. Would love to have the ac keep running as I throttle it up and would love to get my cruise control working. Anyone have an extra one laying around?
I have one...it's the football shaped one.  It is missing one of the mounting tabs.  You can have it if you pay shipping...BUT...they are seriously available in abundance at any junkyard.  The best part is that you don't even need a Jeep one.  You can also make one with a piece of ABS pipe, some pipe caps and a couple of brass (or even plastic) nipples.  Either of those routes would be cheaper than the shipping from CA to OH.
There is really no magic in there.  It's just a hollow space with a check valve somewhere either in line or in the can itself...cut yours open and check it out.  It's a half hour project.
They are usually on every XJ I see at the JY. Behind the bumper on the passenger side. As ParadiseMJ said, you don't necessarily have to have a jeep canister. On my 88 I relocated the canister to mount under the pressure bottle on the firewall. Shortens the tubing run and you can use fittings to tee in anything you need to connect.
