NLeeson Posted June 19, 2014 Share Posted June 19, 2014 I have an '86 Comanche that I bought a couple months ago and it's a great truck (even with all the problems I've read about with the 2.8L) and everything worked fine (that the previous owners didn't already mess up). A couple weeks ago my brake lights, turn signals, and reverse lights all went out at the same time with no warning. I pulled the fuse and it had popped so I threw a new one in it, tested my turn signals which worked, but the instant I stepped on my brake pedal it popped it again. Me and my dad have both been over this thing top to bottom and I have no idea where else to turn. I NEED HELP. Any info on ground connections/locations would be very much appreciated! Thanks. Link to comment Share on other sites More sharing options...
cruiser54 Posted June 19, 2014 Share Posted June 19, 2014 Start by removing the brake light bulbs and duplicating what happens. Link to comment Share on other sites More sharing options...
benjy_26 Posted June 20, 2014 Share Posted June 20, 2014 I had a similar issue with the parking/turn signal lamps in the front of my 87. The fuse would blow whenever I used the turn signals. I swapped out the bulb sockets and bulbs and the problem went away. Link to comment Share on other sites More sharing options...
