Bent LCA mount
Saturday while playing at Haspin I smashed the passenger side LCA mount and that in turn seems to now have my steering wheel turned 90* to the left. :( What fun!
My planned repair is to unbolt the arm and bend the mounts back to straight and then re enforce the brackets with a add on skid plate(like jks or RExpress) and/or a welded gusset.
The arms are RE's and they don't look damaged and the axle is a HP D30
Can i arc weld on the axle housing without disassembling the axle??
any thoughts on this repair are welcome.
thanks
bob
What bounty hunter said is true.... I would weld them using some 7018... depending on your welder I wouldnt turn the heat up but so much cause the stock Lca mounts are 1/8 inch junk. But lca skids, and bracing the sides might help it last a lil while longer.
Patrick
