yxmj Posted May 4, 2014 Share Posted May 4, 2014 What am I missing? 1997 TJ PO had removed the third brake light and butchered in a trailer harness that was causing problems. We found the original wires for the brake light and got it working. tail light has 3 wires coming out of it. harness has 4.....by testing we got the back up, brake and turn working. test light on the 4th shows it is park lights. tried connecting it one at a time with the brake and the turn but it just either lights up all the brakes or stops the turn from working.....were should it go? Any help would be appreciated. . :MJ 1: . Link to comment Share on other sites More sharing options...
64 Cheyenne Posted May 4, 2014 Share Posted May 4, 2014 Wiring schematics? Link to comment Share on other sites More sharing options...
yxmj Posted May 4, 2014 Author Share Posted May 4, 2014 Thanks but just typing that post made a light go off :brows: Brake and signal same wire......other wire was the other side signal...... :doh: Link to comment Share on other sites More sharing options...
