tmaxx411 Posted April 20, 2014 Share Posted April 20, 2014 My clutch is losing pressure at 60+. Below 60, its fine, but if I'm cruising at 65-70, for a couple minutes, when i go to push the clutch in to slow down, the pedal goes to the floor. Pump it a few Times and it works.. replaced master, line and slave not too long ago. Clutch, pressure plate, and flywheel are also new. 89 2.5 ax5 Link to comment Share on other sites More sharing options...
Jeep Driver Posted April 20, 2014 Share Posted April 20, 2014 Internal slave = POS Bet its leaking again. Link to comment Share on other sites More sharing options...
tmaxx411 Posted April 21, 2014 Author Share Posted April 21, 2014 is there an option to convert to an external slave ax5? i don't have the cash to swap to an ax15 currently Link to comment Share on other sites More sharing options...
