Gm Steering
Loose how? Any loose steering components is asking to put your rig in to a ditch or wrapped around a tree.
Edit, saw your double-post. This should help on the repair: http://www.elcaminocentral.com/showthread.php?t=27192
Another good resource is http://comancheclub.com/topic/37167-loose-steering-wheel-fix/?hl=tilt+column&do=findComment&comment=373470
You will want to get on this repair- you don't want to be wrapped around a tree as stated above. As it is you'll have difficulty turning the ignition and engaging the high-beams when the tilt mechanism bolts work themselves loose.
