89 Comanche 2Wd To 4Wd Need Help
I have an 89 Comanche 4 liter 5 speed peugeot 2 wheel drive.
I just picked up a 99 Cherokee 5 speed 4 wheel drive 4 liter.  Can I just use the cherokee transmission, transfer case and transfer case crossmember along with the front axle and driveshaft?  Also, which clutch should I use, or are they the same?
