Oem? Fog Lamps
So I just finished up wiring my existing fogs, added a switch, relay, and new wiring completely. After attempting to turn them on I checked the bulbs and they were not there. Is this the wiring connection or is this silver part a part of the bulb that I still have to remove?
It's an h3 12v 55 watt bulb remove the reflective lens and mounted on the backside is a wire clip that needs to be squeezed together to remove the base of the bulb. Reverse for installation don't touch the glass bulb with your hands it will prematurely wear the bulb out . While your at it sand an paint the reflective piece withe a light silver high temp paint
