Regear Or Bigger Tires?
Here's another thought --
When you swapped in the AX-15 and matching transfer case, did you put the original speedometer drive gear into the transfer case? If not, you are running a speedometer that thinks you have 3.07 gears when you actually have 3.54s, and both your speed and distance readings will be whacked.
