Someone Swapped My Gears..
Hello again, I was attempting to pull my rear axle shafts when I found that the carrier is different from what I see on the d35 guides I see. There is no screw or bolt holding the gear shaft in place so now I'm confused..
It's a 4.0 4x4 5 speed and I tried to determine the gear ratio with the wheels off I got around the stock 3.07 ratio.
It also appears that there is a date on biggest gear (don't know the name) that reads a date ending in '96.
I'm beyond confused and way out of my element now..
Any help will be much appreciated, thanks.
