Electrical Problems
OK, have a few problems and I think they are related but not sure how. First off, my reverse lights and climate control panel back lights sometimes work and sometimes not... The reverse lights will come on if i Jiggle/turn back and forth the dimmer/ headlight switch. However the climate control back lights will just work on a random limb every once in a while. Also the dimming switch doesn't dim. It has a short or something I think. Turn it back and forth and it is on or of and flickers. Any Ideas?
I have a 1988 mj 4.0 4x4
Off topis but While I do that I'm going to try to switch out the gauge cluster bulbs with Leds anybody done this before and have any input?
http://comancheclub.com/topic/41036-retired-stormtrooper/?p=414630
From what I understand, without an LED dimmer in the circuit, the LEDs will be extremly bright and non dimmable.
