Rockdrummer93 Posted January 9, 2014 Posted January 9, 2014 I am selling my Jeep XJ Cherokee axles. Front will bolt right up to any TJ, MJ or XJ. Rear will need brackets unless used in a stretch application. Front: - High pinion Dana 30 out of an 97 Jeep XJ Cherokee - USA Standard 4.88s - Aussie Locker - Stock shafts w/ spares - JCR 1 Ton over knuckle steering w/ spare tie rod - TnT Over axle trackbar bracket - Alloy USA outer tube seals - JCR Raised Sway bar mounts - Riddler Diff cover - Brakes included Rear - Dana 44 out of an 89 Jeep MJ Comanche. - Yukon 4.88s - Alloy USA Chromoly Shafts w/ spare Chromoly shaft - Relocated breather tube - Riddler Diff cover - Does have leaf brackets for 1-3" of stretch so will need new brackets if putting on a stock XJ Will need after market track bar. May split up. These are still under my Jeep so serious inquiries only. NO TRADES. Asking $2000 for both, $1200 for the front or $1000 for the rear. All offers are somewhat negotiable. Located in Greenville, SC. Can drive up to an hour to meet for a sale if serious. Call or Txt me at (864) 404-0596
Rockdrummer93 Posted January 16, 2014 Author Posted January 16, 2014 Pricing now somewhat negotiable.. May split up.
Archived
