Blaine Posted December 30, 2013 Author Share Posted December 30, 2013 found great YouTube vid for replacing the seal, here is the link, still don't know if that will take the play out and i pray its not the pinion bearing. if so i know the main procedure to do it, once you press the new bearing onto the pinion shaft and put the crush collar on you slide the pinion gear into place in the axle, after the new races have been installed of course. you put the other bearing in then the seal, slide the yoke on and tighten that nut to torque which will crush the collar, is that it? i want to make sure the pre-load is right and pinion to ring is correct. Link to comment Share on other sites More sharing options...
cruiser54 Posted December 30, 2013 Share Posted December 30, 2013 Ok looked over the front driveshaft and you were right cruiser, one of Ujoints were bad, another thing though is there is play in the yoke on the front diff, with oil slowly coming out, so the seal needs replacing but will that fix the play, and is there a crush collar as well? this is not mine this is a ref. picture, basically the yoke can move up and down What kind of play? Up and down? Link to comment Share on other sites More sharing options...
Blaine Posted December 31, 2013 Author Share Posted December 31, 2013 yep would replacing the bearing right behind the yoke take care of it? Link to comment Share on other sites More sharing options...
cruiser54 Posted December 31, 2013 Share Posted December 31, 2013 yep would replacing the bearing right behind the yoke take care of it? Not my area of expertise. Link to comment Share on other sites More sharing options...
