coyote kid Posted December 15, 2013 Share Posted December 15, 2013 My antifreeze mix was wrong and it froze into a thick slush I got it running but it has a miss at idle now and overheats quick and shoots steam from the intake manifold seal it also has steam from exhaust that smells like antifreeze where should I start ?? Is my block cracked and my motor toast ? Its a 88 2.5 ax4 Link to comment Share on other sites More sharing options...
Jeep Driver Posted December 15, 2013 Share Posted December 15, 2013 Coolant runs through the intake manifold too.........I'd start there.......next is the head. Sorry man, that sucks. Link to comment Share on other sites More sharing options...
MancheKid86 Posted December 15, 2013 Share Posted December 15, 2013 ouch,I'm with jeepdriver, hopefully it just blew the intake seal, causing a missfire where its leaking into the manifold to the cyl,which makes sense for it steaming out the intake manifoldnext is the headwhen you check your intake gasket you need to drain the coolant anyways,when refilling save the hassle and buy a jug of premix :thumbsup: Link to comment Share on other sites More sharing options...
coyote kid Posted December 15, 2013 Author Share Posted December 15, 2013 I will try to fix it but if I can't I don't care because I have a built 300 hp 318 sitting on a stand that needs new home hehehe Link to comment Share on other sites More sharing options...
MancheKid86 Posted December 15, 2013 Share Posted December 15, 2013 I will try to fix it but if I can't I don't care because I have a built 300 hp 318 sitting on a stand that needs new home hehehe then you did a good thing, slap that baby in Link to comment Share on other sites More sharing options...
coyote kid Posted December 15, 2013 Author Share Posted December 15, 2013 Haha been meaning to find a time to stick that motor in there for 2 years Link to comment Share on other sites More sharing options...
