jared Posted April 15, 2007 Share Posted April 15, 2007 which way do the driveshafts spin on a jeep? clockwise or counter clockwise? Link to comment Share on other sites More sharing options...
comancheman Posted April 15, 2007 Share Posted April 15, 2007 CCW for forward CW for reverse i think Link to comment Share on other sites More sharing options...
Pete M Posted April 16, 2007 Share Posted April 16, 2007 Doesn't that depend on whether you're looking at the t-case or the axle? Link to comment Share on other sites More sharing options...
Duner Posted April 17, 2007 Share Posted April 17, 2007 rotation direction is generally stated from driver seat point of view while car is moving forward. This equates to CCW for forward for most rear drive cars made. Or if you face the engine while it is cranking you will see it turns CW from this point of view which translates to CCW from the driver's seat. Link to comment Share on other sites More sharing options...
jared Posted April 17, 2007 Author Share Posted April 17, 2007 so the rear driveshaft is couter clockwise, then what about the front is it reversed or the same? Link to comment Share on other sites More sharing options...
Pete M Posted April 17, 2007 Share Posted April 17, 2007 The transfercase chain will dictate which way the front spins. :D Link to comment Share on other sites More sharing options...
jared Posted April 19, 2007 Author Share Posted April 19, 2007 well if the jeep was going forward in 4wd the rear driveshaft would be spinning ccw, and the front would be spinning? i can't figure it out myself i need someone else to look while i drive. Link to comment Share on other sites More sharing options...
Pete M Posted April 19, 2007 Share Posted April 19, 2007 The d-shafts would be spinning in the same rotational direction. The chain inside the t-case makes sure of that (it wraps around both sprockets). Whether you call it clockwise or counterclockwise depends on your perspective. When you start to go forwards, the top of the transfercase chain would move towards the drivers side (CCW if viewed from behind the t-case). Both d-shafts must follow suit. Link to comment Share on other sites More sharing options...
